Ford 8.8, LSD (track-lock), manual tranny....I HAVE to run 75W-140 due to warranty BS..so I cant run the 75W-90 like most of you guys suggest.
Which oil (or other alternative brand?) will be better for my application..it is a toss up for me and both run about $7-8/quart
RL:
RL:
Royal Purple:quote:
75W140NS
Gear Oil
Recommended for manual transmissions and non-limited-slip transaxles that recommend 90 WT oils. Can be used in racing limited-slip units to increase lockup and reduce wheel spin. Street-driven rear-wheel drive cars should use regular Red Line 75W90 or 80W140.
quote:
75W-140
Max-Gear® is recommended for use in truck and automotive front or rear differentials, manual transmissions and lower gear units of marine engines that specify use of an API GL-5 or GL-4 fluid.
Max-Gear® is an ultra-tough, high performance, GL-5 automotive gear oil designed to provide maximum protection to heavily loaded gears while maximizing power output throughout the drive train. It outperforms other GL-5 gear oils because it combines the highest quality synthetic oils with Royal Purple's proprietary Synslide® additive technology.
Max-Gear® makes gears run smoother, quieter, cooler and longer without overhauls.
