http://www.racecar-engineering.com/cars/mclaren-mp4-27/
Quote:
With no stone left unturned in the quest to be the best, our Mobil 1 engineers have developed a breakthrough engine oil for 2012 that allows a significant increase in the engine operating temperature.
The MP4-27 uses oil and water radiators to help cool the engine. Located in the right-hand side pod, the oil radiator and Mobil 1 technology provide an almost equal share of the engine cooling requirement. There are several advantages of being able to run the engine hotter. Drag can be reduced by re-optimization of the radiator and aero packaging. Increased rear downforce can also be achieved through aerodynamic improvements to the exit ducts.
The Mobil 1 engine oil flows through the radiator cooling down by approximately 40°C, whilst the air channelled through the side pod inlet heats up about 75°C. The excellent thermal performance of Mobil 1 technology is one feature that allows both higher operating temperatures whilst still protecting the engine and is a real advantage. When the winning margin can be fractions of a second, using the right engine oil can make the difference.
