Originally Posted By: bxd20
So if your engine is leaking or burning oil badly enough that you need to add a quart before it's time for an oil change, just add the quart.
Depending on your oil change interval, a qt of top off oil isn't really that bad....but when I do "top offs" I only add 1/2 qt at a time. I'm one of those that keep it between the full and the add line, not "at" the add line. I've found my car actually consumes more oil when at "full" than when it's between the "full" and "add" lines.....no idea WHY, but that's just the way it is.
But yea, I've been using Pennzoil Conventional 2 OCis now, first OCI was about 5k, and I added 1 qt. This OCI, I'm coming close to the 3k mark, and the oils looking a little low, but not at/below the add line yet.
Bottom line, no, I don't find it necessary to have an "Oil Change" at the 3k mark, if the oil still has a decent sheen to it (i.e.: not extremely dark....) - some older cars come to a point in there life where it can be considered a "Filter Change" rather than an "Oil and Filter change" since you're constantly adding NEW oil to the engine lol....but I still personally wouldn't go more than 8k on a "standard" oil filter. But be my guest to "top off" and away until that 8k mark
