Hi there,
FR730V is on cub cadet zero turn SX54 inch mower.
it appears that the fitting at the engine housing is leaking oil.
can there be an O ring issue. how do I know the size?
Also, can I drain oil and change the O ring and put the drained oil back? or I need to change the oil? right now , the oil is new but if I mow, oil will get used. never drained the used oil and put back same oil hence asking.
