Kawasaki fr691v smokes badly
Are those all of the second ring? So it looks like the second is a Napier ring and the notch has to go down. That should put the markings up, correct?
How about pics of the top ring?
Yes those are all the second ring. It looks to be a Napier style but i am not up on piston rings. When the groove is facing the bottom of the piston then the pink mark is on the right side of the ring gap and the laser etched 2R is facing the top of the piston
So it seems like the instructions are saying for a new ring place the paint mark on the right side of the ring gap which would place the groove facing downwards but for a used ring to place the groove facing the top of the piston?
Manuals aren't absolute - the markings always go up unless specifically noted by the ring manufacturer or the OEM. Since this is a Napier, the "groove" goes down.
Can you post some pics of the top? Most likely it will have a chamfer on the inside, which will go down - this ahould put the "1R" marking up.
The top piston ring looks symmetrical. I dont see any difference between the top and bottom.
Its called a Napier style piston ring and it looks like its supposed to face downwards. https://www.enginebuildermag.com/2025/09/how-to-identify-piston-rings-and-proper-orientation/
First, I was about to say the manual is wrong, but then you pointed out that it mentions two different scenarios when you use:
1. New second ring
2. Reassembling the original second ring
In this case follow 1. - the white marking direction facing right as the manual says.
Also (from what I know), by default the first/top ring is always installed with any lettering/numbering (1R) facing upward. Not sure if that is valid for the second ring as well.
For a peace of mind just write a short email or call Kawasaki USA and they will tell you.
The paint marks may not be relevant at all in this case. When was the manual written in relation to this specific engine? Does this actually apply to this engine? OEs are guilty of being lazy and copy/pasting too - I've seen it a few times. Is this the same manufacturer of rings that was used when the manual was written?
What does matter is that the rings are installed according to their design. The top ring appears from the pics to be symmetrical, so just put the marking up. The second ring is a Napier design so the groove goes down, which also happens to place the markings up as well.
By placing the second ring with its white marking facing right (as the manual says) also orients its groove facing down.
So, the manual is correct and matches what I-net sources say too.
I am going to install the rings with the laser etching facing up which makes the napier ring face downwards so it can properly scrape the cylinder. Everything i read about this style ring says it must be installed facing the bottom of the piston.
Update. Motor is basically back in the mower. Still have to bolt it down and attach all the externals plus adjust valves. I did a transmission fluid change while it was out as it was a lot easier to access the bleed plugs. I assume the transmission oil was original. The filters were the white hydrogear filters and were on super tight. While the transmissions were quiet when driving around the oil did have a decent amount of very very fine metallic particles that were probably in there from break in. Also the fluid definitely had moisture mixed in as it was milky. Replaced with Mobil 1 15w50.
Update: I spent the weekend putting everything back together. The engine is completely assembled and all of the steering and transmission linkages are adjusted according to the manual. I started it up and it didn’t immediately explode so thats good. It seems to run great. There is zero smoke from the exhaust now. I drove it around and varied the engine rpms. Even after warming up there is still no sign of oil in the exhaust. Overall it turned out great. The manual did have a couple confusing parts/typos but with your help i was able to get it assembled properly. Thanks
I guess that means you got the rings in , in the correct direction! Nice!
Nice job!
Great job!
Did you replace all gaskets b/w the engine block and the cylinders and b/w the cylinders and the heads?—I'm sure you did, but just checking.
Also, did you replace the oil pan gasket?
Change the first oil and filter at 1/2 or 1/3 of the factory recommended oil change interval. If there is no oil filter change it at 1/4 of the recommended interval.
Great job!
Yes all gaskets were replaced. Its basically a factory fresh engine except it only got new rings. Everything else was is spec.
I need help setting the governor. I tried to follow the factory service manual for setting the governor and then setting the throttle stop. The issue i am having is when the governor is set per the manual the throttle stop for max rpm is backed all the way out and im still only getting 3200 rpm. The engines rated for 3600rpm and i want 3600rpm. And yes cub cadet rates the engines for 3600rpm as well for this specific machine.
Did you complete this procedure:
• Turn the top end of the governor arm counterclockwise to fully open the carburetor throttle valve and hold it there.
• Turn the inside governor arm counterclockwise fully to the end of its travel.
• Tighten:
Torque - Governor Arm Joint Bolt [H]: 5.9 N-m (0.60 kgf-m,
52 in-Ib)
Governor arm joint bolt is left-hand threads.
• Install the control panel assembly...
• Tighten:
52 in-Ib)
Yes. The inside governor arm i moved fully counterclockwise and then moved the outer governor arm attached to the throttle to fully open the carburetor butterfly which moves the outer arm counterclockwise. Then i tightened the bolt.
