New 372XP OE Purchase
Erie, PA
Here is the definition of stage 4 CAD.
I ended up getting a super ugly medium - high hour one locally a while back, and ended up liking it so much decided to get a brand new one before they are completely nla.
Robin Wood has some Sweden models left and I decided not to wait any longer before they were completely NLA.
While I am thrilled to have been able to aquire one, there are some differences right off the bat. The overseas model ships with a pipe outlet muffler without the reinforcement bar and minus the spark arrestor screen. It also has the Gilardoni cylinder VS the Mahle offered back in the days we had them. Looking thru exhaust port it has the one ring piston. Last thing I noticed is there is no safety verbiage sticker or EPA sticker on the tops cover.
The Mahle vs Gilardoni OEM cylinder debate is a bone of contention among many but in the end both are excellent. The chrome plating on both are top notch, however visually the Gilardoni castings are more rough cosmetically. This translates to slightly more power in stock form, not enough to notice. The marbled / rough surface agruably helps with the intake and transfer ports. Both Mahle and Gilardoni port well unlike the crappy aftermarket cylinders.
Started right up, but man o man is this thing tight. It needs to break in quite a bit. Even the bar and chain is super stiff. I am keeping the tune quite rich for safety.
Cold Start: (Skip to 1:00 to save time)
Looks very familiar! I mine is a 2003 I believe, so its the same saw but with the top outlet muffler with the spark arrestor. I run it with the arrestor out.
I guess I should check the compression sometime, but I certainly still use the decompression button to start it. It has not had an easy life but just basic maintenance is all that its needed. 32:1, and I use the same air filter that your saw has, not the mesh one.
I have a 36" full skip bar and chain for it too.
Added some inside photos. I always tear down my new saws for inspection out of habit, as it only takes 10 min on a 300 series saw and maybe 15 or 20 to re assemble.
I wish I was small engine savvy. I am not. I have a 455 Rancher that was running rough. Took it in. Paid $250 and it still can’t stay running. Idle speed screw perhaps?
I bought a 372 as a gift to myself when I finished trade school. It was either this or a Henry rifle. The saw was cheaper. I was expecting it to be made in Brazil, but thankfully it’s Swedish made.
Here’s my cranky son with the saw. (No oil/ gas in it.) He is named after a guy who was like my grandfather. Cut wood to heat his house with a west German made Stihl S10. Pulled the wood sled with draft horses. The photo seemed appropriate.
Great purchase! I bought a 365 Xtorque back in 2021 after losing a smaller saw in a storage unit theft. The 365 was on significant discount after sitting on the shelf for 4 years. Its startup was about exactly like your video.
Might recommend getting one more felling dog to go on the outside chain cover. There's a small plastic self-tapping screw to hold it in place, if you want. I never bothered and just slide mine on with the bar and cover each time.
Two felling dogs help to square up the saw to the log and give better grip.
I got a 20" bar with it but ended up going to a 28". Skip tooth full chisel rips through hardwood. Enjoy your new purchase!
First Start. I did inject some oil down the carb throat and in the cylinder before the camera.
Skip to 1:00:
