The easiest choice is what @Freischneider posted . Price is good toowhat brand weight,type would be the best for a kawasaki FR691V engine in a new Gravely zero turn,a neighbor just got,i recomended Amsoil 10w-40 ASF small engine,,,anything better??,,any thoughts,,5w-40??
ASF would be excellent choice no need for 5w anything unless you plan on mowing in 0F temps, depending on temperature you may want to go with 15w50 SEFwhat brand weight,type would be the best for a kawasaki FR691V engine in a new Gravely zero turn,a neighbor just got,i recomended Amsoil 10w-40 ASF small engine,,,anything better??,,any thoughts,,5w-40??
Where do you find it for $4 a quart?
This is what I use in mine. I have Valvoline premium blue 15w-40 in it now, doesn’t burn a drop of oil.I would recommend any HDEO 15w40. Easy to find, cheap, and works well. I've run it in quite a few Kawasaki powered commercial mowers.
Mobil 1 15W-50 in the engine and hydros...Nothing to worry about.Just purchased a slightly used (less than 6 hours) Gravely ZT HD44 zero turn with Kawasaki FR651V motor.
The Gravely manual list a Gravely 15w50 synthetic with zinc for use in both the motor and Hydraulic drives.
https://www.amazon.com/Gravely-5-Pack-Synthetic-Hydraulic-00057100/dp/B08XN6GW4Z
Kawasaki sells a 15W50 synthetic with zinc.
https://www.amazon.com/gp/product/B081P371XX/ref=ox_sc_act_image_1?smid=A2USNRRU3IZJB9&psc=1
Will the Kawasaki version work in both motor and hyd drives ?
There's a sweet young thing that works at the mower shop that hooks me up.Where do you find it for $4 a quart?
I used the 10w40 ASF for 140 hours and it worked great in my FR731V. When I drained it I went with HPL Small Engine Life 10w40. Either oil will suit you well, as will some of the others mentioned.what brand weight,type would be the best for a kawasaki FR691V engine in a new Gravely zero turn,a neighbor just got,i recomended Amsoil 10w-40 ASF small engine,,,anything better??,,any thoughts,,5w-40??
