Kawasaki, 38.5 HP
Kawasaki FX1000V 38.5 HP
Hello, I have purchased a new Scag V Ride XL mower, what is the oil you all recommend it calls for 15 50 weight
Should go with the high zinc oil as pictured
Wait until @Zee09 see's that HP number.. He'll be ready to drag race you in his gray ZT.
20w-50 for lower hour (more frequent changes) would work too but the 15w-50 recommendation is what you want in commercial duty if following the oil drain interval in the manual.
Commercial use? You don't say.
There are many homeowners who have commercial mowers because they cut 10 acres of grass (like me). I run Mobil 1 Euro 0w40 in my 28HP ZTR engine and an FL400S filter. I mow grass in the spring and fall as well though. Wouldn't hesitate at all to run Mobil 1 15w50 in it though, that is what is in the hydro drives.
And what is the manual for? It has no mention of the 15W-50 ?
For cheap oil you could do like some other folks do and just drain the oil out of that old car thats been sitting a few years, and use that. 🤣 🤣 🤣 🤑
Manufacturer definitely allows 50 grade
