K&N Oil Filter Betas?
Iowa
Has anyone else tried to contact K&N to get some idea of their oil filter efficiencies? I sent an email but never heard back.
I was just curious as to what they are and would like to hear something from the "horses mouth" or someone else that has rather than guessing.
Thanks in advance.
Update: I got an email back from K&N yesterday asking what model filters I use, so hopefully they will send me some specific info on these.
Meanwhile, I don't know if it is a current efficiency rating or not, but I stumbled on this BITOG post from 2002: https://bobistheoilguy.com/forums/posts/309373/
Stating 50% @ 16 microns and 98% @ 35 microns.
You missed my 2008 posting of specs for a K&N NP-6001 (Ford Powerstroke Filter):
10 um- 53.1 %
20 um- 95.4 %
30 um- 99.9 %
Capacity- 55.4 grams
Hydrostatic Burst- 558 psi
Element Collapse- 175 psid
Flow Rate- 20 GPM (J-806)
Betas- 10/20/30=2.1/21.7/1000
Thanks Jim! That's like I was looking for!
So it's comparable to the M-1. That's good to know.
The K&N HP-1004 I used, according to K&N via email on 9-30-09:
Filter media efficiency (per ISO 16889):
100% at 40 microns
100% at 35 microns
100% at 30 microns
99.4% at 25 microns
98.9% at 20 microns
97.1% at 15 microns
92.3% at 10 microns
82.5% at 5 microns
Wow ... that's quite a PSID before the element collapses. I would have expected it to be much less than that. It's too bad the manufacture's don't give data on PSID at some flow & viscosity point to give the customer an idea of flow resistance.
82.5% at 5 microns
Fantastic! Twice better then Pure One (51% only at 5 microns)
p.s. But 82.5% is according to ISO16889. How much is it at common-used (Purolator, AMSOIL, CHAMP, FRAM, ...) ISO4548-12?
I don't understand why K&N have used ISO16889 (for hydraulic or fuel only) instead of ISO4548-12 (for lube oil).
82.5% at 5 microns
Comparing two different ISO standards, so might not be a direct comparison there. The PureOne 51% @ 5 um is ISO 4548-12, where as the other is ISO 16889.
Probably to make it look better.
