K&N for my 5.0 Stang?
ohio
Which is more important; flow rate or filtering ability? K&N seems to flow good but Purolator seems to filter better. I'm leaning towards K&N for flow rates.
K&N will give a very decent flow rate.
If you change your oil very often, filtration probably won't be a major deal.
I'd go with better filtration. Look at AMSOIL EaO filters.
That seems to be the consensus,
running through the search function and came across this:
the best filtering - Amsoil
almost best filtering - Mobil-1
good filtering and the best flow ...... K & N (plus if you are not good with tools, these have a big nut for idiots)
want the best filter for the money......PUROLATOR BABY,
PURE - OR - LATE - ORE !!!
Originally Posted By: Spector
Anything worth filtering cannnot be captured by todays filters, Go with the flow!
What is it that's worth filtering that filters like Mobil 1 or Amsoil cannot capture?
As long as the filter's media is big enough to catch rocks and birds, it's good enough! :) Go with the flow! :)
Micron filtering - associated with Mobil 1 and Amsoil Eao, seems to help the long (double-digit) OCI folks most -- or those that change filters every-other-OCI.
less then 10 microns! Most filters capture above that and what is really unknown is what damage "if any" less then 10 micron particles can actually cause and how much if any they actually reduce the life of an engine.
[/quote]
On some cars like my Mazda6s, us idiots need that nut on top because of the location of the filter. Don't comment on sonething you don't know.
I think he's saying you can use it instead of making a strap wrench or filter wrench work, not calling you an idiot for using.
Both filtering and flow are very important wile poor filtering can damage a motor so will poor flow. I go with a good name that you can trust one that has been around for a wile and who has been makeing oil filters. but I'm not here to endorse any particular brand cause everyone has there own personal preference on what is good and what's not. But I know through experience that the purolators have always been reliable for me and my 5.0 stang never had any problems with low oil pressure or and thing along the lines of a oil filter or oil system error
How does a filter make your oil pump ..pump more? I keep seeing this time and time again. How does a filter magically give your oil pump more volume output? A filter, in all but the most marginal of circumstances, can only make oil pumping (in terms of factional/micro hp) easier.
