Originally Posted By: barlowc
Originally Posted By: ltslimjim
I just prefer low Si and if it's allowing in an unacceptably elevated amount of Si, then I would not use it. So far, it hasn't been terrible with the K&N in my app, but enough to make me feel annoyed.
What does "low Si" mean quantitatively? What is considered "unacceptably elevated"? What is the amount that makes you feel annoyed?
When you have choices, there is no need for anyone to be annoyed.
If you look around objectively, you'll find that oiled cotton gauze (OCG) filters are at the low end of the filtering efficiency scale. Not disastrously or instant death low... just lower. How much lower? It's about time to make another survey, but last time I accumulated comparable data, the averaged OCG filter tests I could find yielded a high 98 percent range (see note on filter tests below). The OEM can easily match that today and premium dry media filters are in the high 99 percent and don't cost any more than the OCGs on the market.
How much a 1-2 percent difference in filtering efficiency mean? Depending on where you live, maybe not much. Or maybe a lot! If the area where you live has generally clean, low dust air, an OCG filter will be fine. If you live where there is a lot of fine dust, not so much... and it will show up in the UOA. Eventually it may show up in a shorter engine life. Less silicon is always better. Single digits are "acceptable" by most any standards. Some labs have slightly higher or lower condemnation rates but I really haven't looked around to compare them. High silicon is a long term issue, not a short one. To me it's just common sense to go with the highest efficiency media and try to keep the silicon low. But I drive my cars for decades. Might not matter much to somebody who trades in regularly.
The larger concern for me regarding OCG filter is down the road. Cleaning. An improperly cleaned OCG filter can get into the "disastrous" region fast because they are so easily damaged (as is the one in the picture).
OCG had it's day. Back in the '60s and '70s, they were superior in efficiency to oil bath and many old style cellulose filters. That was the day when you hoo-rahed getting 100K miles from an engine. In those days, many air filters were too small for the application if you wanted any performance, so changing to an open, free-flowing filter often unlocked some power and did so with equivalent filtration efficiency. Win win, for sure.
Today, most intake systems are pretty efficient and the average engine can easily do 200K with a modicum of care. They are well designed too and intake systems are one reason today's engines are so much more powerful per cubic inch of displacement than they used to be. The OE systems are so much better that aftermarket stuff doesn't show up quite so good any more (on an otherwise stock engine).
If you are going for an aftermarket filter for the performance aspects, fair enough. Bear in mind two things, a) you can have 99+ percent filtration with a performance system, and b) in an otherwise stock engine, you aren't likely to see any gains from a drop-in filter that uses the original intake system. You MAY see some gains in the upper rpm range with a system that replaces all the intake tract with something tuned but that's variable according to, a) how good the new system is vs the old and, b) how well designed the new piece is.
Finally, look closely at the filtration efficiency tests you might see published. There are some that use the equivalent of gravel for test dust and others that use fine dust. I was once fooled into accepting OCG filters as "better" based on a test done in the UK but then it was pointed out to me that hardly any fine dust was used in that test, so of course it came out good. I'm not going into all the wherefores here, just advise getting the details of any tests you want to compare and make sure you are comparing apples to apples in terms of the test conditions (e.g. the type of test dust used) in any filtration tests. A good test will list the type of test dust used (e.g. ASTM "Fine" dust) and often it's general makeup in particle size.
