K&N HP- 2010 was in service for 2 5k Intervals in my van with Castrol Synblend 5w20-5w30 oil, it looks solid, I went back with the same filter and oil for another 2 - 5k intervals.
Just looked at the hp-1010 in Walmart and it's an e-core now
My jaw dropped when reading your reply. If that's true and see no reason to doubt what you saw, I'll look for changes in the Champ Mobil-1 filters too.
All good if they don't leak right away at the bottom nut welds. My son's mustang made a mess when he started it up with a K&M that had a burned through weld.
I was just about to mention the leaking welds.
No way I'd use any K&N oil filter.
I've run nothing but FL820S oil filters on a Crown Victoria with 350,000 miles with no issues but they are the "worst oil filter, etc etc"
Same with these K&N, I've ran so many and not 1-issue
I looked at the Mobil 1 and it was still a metal center tube just the updated base plate
