Just fixed my A/C!
Awesome fix. I'm assuming you purchased the correct capacitor? When I worked maintenance I was starting to learn a little bit about A/C and there is a range and something else to look at farads If I remember correctly.
mF and voltage rating. Supposedly using a higher voltage rating than the original capacitor will make it last longer, but they are physically larger so you may need to make up a larger bracket.
Store spare capacitors in a cool environment if you can. Parts degrade and age less if kept in a cool environment during storage. I would not freeze them because that may actually degrade them more but I would go for a cool environment. Even though they do get exposed to freezing temperatures sometimes outside.
