Just a thought on mass shootings
Originally Posted By: Cristobal
Originally Posted By: dishdude
Here's a thought - how about less of these ridiculous high powered weapons like the AR-15 used in this one floating around.
Because then they will be confiscating hunting rifles right and left.
Then you should man up and hunt with a bow and arrow.
If you can't kill it with a bow and arrow, you probably don't have any business being in the woods in the first place.
BC.
BC.
And if I wanted the firearm for the equally legitimate purpose of self-defense? If, perhaps, I was elderly, or perhaps the bow was too unweildy or ineffective for self defense?
Actually, the current story is he had a shotgun, used that to get a pistol from a guard, then used the pistol to get an AR from a LEO.
Let's settle the truth if it ever gets out.
Using those guns to kill people was.....wait for it..........ILLEGAL. Bringing those guns there was.....wait for it..........ILLEGAL.
Originally Posted By: bdcardinal
An AR-15 isn't exactly "high powered" It fires a common round used for varmint hunting.
And goes through body armor, car doors, etc...
Car doors are thin metal, I blew holes through one with 12 ga bird shot and 135gr .40S&W. Body armor can stop a .223 round, they can stop 7.62x39 as well. Now a 6.8 SPC or a 6.5 Grendel or a .50 Beowolf, those are high powered rounds.
Um, military body armor stops neither the 5.56mm nor 7.62X39mm in most cases at realistic combat ranges. Many dead and wounded U.S. vets from Iraq will attest to that. And both rounds have killed far more people than the super-macho bad-[censored] killer calibers you mentioned. I mean only super ninjas and Steven Seagal like are capable of wielding such juggernaut like bullets in actual combat...
I would also like to point out, for clarification, that this shooter was in the Navy Reserve as an Aviation Electrician's Mate, 3rd class. He was unlikely to have received any firearms training, whatsoever, during his 4 years of service...his service record did not include any medals for marksmanship, nor did he deploy overseas, where he would have received some firearms training...
Depends on the level of armor, a cermaic plate will stop .223 for a few rounds.
But as for "high powered rifle" my AR chambered in 5.56x45 is a weakling compared to my SOCOM II in 7.62x51. I can shoot the AR all day and twice on Sundays and not feel any pain.
Originally Posted By: Astro14
Rifles are rifles. Body armor (of the soft kind that cops wear) is generally only effective against handguns.
Same with military body armor, the U.S. service personnel in Iraq were the most armor clad ones in history, and they still suffered horrific gunshot wounds from the pedestrian AK. They also inflicted equally horrific ones with those "varmint" killers...
Quote:
ANY rifle round will penetrate it along with car doors. Regular hunting rifles have a lot more power (mostly from bullet mass) than an AR-15. What makes the AR-15 easy to shoot is its LOW recoil, a result of LOW power in a lightweight rifle.
Then whey don't U.S. troops carry regular hunting rifles into battle? Why no .60 caliber musket balls? Thems real man's ammo!
But as someone who shot them often, they are "easy" to shoot, especially in prolonged engagements. It is lightweight, allowing the user to carry far more ammo then previous service weapons. And the bullet itself is hardly "low power." It flies at over 1000 meters per second at higher velocity than larger caliber rounds such as the .30-06. The slug is small, but the yawing effect can be rather horrific and led to investigations as to why numbers of North Vietnamese soldiers would often flee after being shot and found dead while appearing to be hiding after - because the bullets would often break apart causing them to internally hemorrhage to death. Much the same way Union and Confederate soldiers used to pull off their clothes before dying to try to pull out the massive musket balls they could feel killing them...
Quote:
The USAF (and soon after, the Army) bought the M-16 (andAR-15) because it was higher capacity, lightweight and EASY to shoot...not because of the power or effectiveness of its caliber.
The first M-16's were not "higher capacity", they had 20-round box magazines like the M-14 did. I'm not sure if you get your history from "The Manuel of the Disingenuous" or from somewhere else. The weapon was ordered after General Curtis LeMay saw a demonstration of them ripping apart watermelons and everything else they hit at a Fourth of July picnic. He was pleased because the Springfield factory could simply not produce nearly enough M-14 rifles, which meant that up into the mid-1960's, many U.S. servicemen would be carrying obsolete M-1 Garands, Carbines, and Grease-guns into combat against Soviet troops operating AK-47's. The M-16 survived the best attempts to kill it by conservative 'one-shot, one-kill' officers because it was a very effective and it was needed in the jungles of Vietnam.
The weapon was born out of numerous experiences and research including that conducted by the British, Germans, and the U.S. Army after WWII that full caliber "hunting rounds" were superfluous; and that solders rarely shot each other at ranges beyond 200m, maybe 300m max.
Quote:
They knew then that the .223 was far lower power than the .308 that it replaced in the M-14 but the decision was to buy a lighter, higher capacity rifle.
The 5.56mm generates quite a bit more muzzle velocity than the 7,62X51mm. It's also because special operations troops tested the first M-16's in Vietnam, and loved them. They also found that in early small unit infantry engagements, the U.S. Army and Marines were often coming off for the worse against frontline formations of the North Vietnamese Peoples Army armed with AK's, because in the unmacho, unglamorous world of actual combat, the truth is that the unit that gets the most rounds out usually wins the engagement. As mentioned, the rate of M-14 production was too slow to arm the U.S. military adequately. Also, many senior infantry officers had been junior officers during Korea, and had had bad experiences of entire small units of U.S, infantry being wiped out in night engagements by the Chinese "Volunteer" units armed entirely with Soviet PPSh-41's - and even Thompson sub-machine-guns that were supplied to China's previous Nationalist gov't, while their troops were frantically trying to reload their M-1's. The M-16's were also more compact and easier to wield around in enclosed spaces of cities and jungles during actual combat. This is why the British troops in Northern Ireland often felt at a bit of a disadvantage against IRA members carrying "Armalites" in the 1970's.
Quote:
But the press uses words like "high power" for their sensational effect...without knowing what they mean...or caring about technical accuracy....and those terms get parroted....again without understanding...
Just like some belittle others' intelligence with silly aphorisms without acknowledging that nearly every major military uses "small caliber" assault rifles for one reason: they are simply the most efficient means to kill people at combat ranges and have been proven in nearly every major conflict since the 1970's. That's not to say that weapons like the M-14 (and SOCOM derivatives), FAL, G-3, etc. aren't excellent rifles that have their place situationally on the battlefield. But weapons like the M-4, FA-MAS, Enfield, or Steyr are superior for general usage...
Which becomes a huge factor with soldiers in combat that find themselves physically exhausted, deprived of sleep, dehydrated and possibly hungry and even somewhat malnourished...
Here's a thought - how about we look at the criminal, not the means by which he commits the crime. This kid had previous firearms crimes, prior mental health issues, both of which should have been reasons to keep him away from guns and keep him off a military base.
I couldn't agree with this more...
Tim McVeigh did a lot more killing with fertilizer and diesel fuel, which remain unregulated. Should we get more restrictions on Ryder trucks, diesel fuel and fertilizer to hope that those restrictions make us safer?
but...
killing people is not the main function of trucks and fertilizer. How often are they used to kill people, versus their NORMAL INTENDED USE?
Guns, on the other hand...what's the main NORMAL INTENDED function?. hmmmm...painting pictures...now wait! it's not. I think you know what the answer is. ( To shoot/harm/kill living beings,humans included)
How often are guns used to kill people versus hammering nails with them ? (as an example). The point (and truth) should be clear.
This is just as idiotic as people die in car accidents, why don't we regulate cars? LOL !
BC.
Why are you getting insulting? I do not think that ad hominem attacks have any place on BITOG.
Archery and guns are equally good for hunting, and I have used both.
I attempted to be brief to make the point about M-16/AR-15 and "high-powered".
But I don't subscribe to "The Manuel (sic) of the Disingenuous"...I am well aware of why we bought the rifle, but there is not crystal clear consensus on the "why", over 50 years later, but there is simple comparison to help those not as informed about the "scary black rifle"...and yes, I own one, and yes, I have some military experience...
Originally Posted By: 97tbird
but...
It is precisely because arms are designed to kill other men that they were protected in the Constitution - because without the means by which to defend yourself, you really haven't the right to defend yourself...
Seeing as these things happen mostly in the USA, it seems it's just a culture thing. Something that's not likely to change, and denial doesn't get you any further along to resolving the problem.
Silk - I agree that firearms are deeply rooted in our culture. We have always been so, and the bill of rights (1st ten amendments to our Constitution) reflected the early American belief that everyone had a right to both personal and collective defense. We exercised that right a few years prior in a political struggle against the British empire...
The question before us, though, is how to enforce the equally valid precept that criminals and the mentally ill should not be allowed to enjoy that freedom to bear arms. Each one of these mass shootings had, at its heart, a shooter who was mentally ill...in this case, a shooter who was kicked out of the Navy for anger issues and who had a shooting incident a few years ago.
But is this relevant in the 21st Century ? Yes, because other people have guns and they might kill you...it just goes around in circles. It seems the American culture is very resistant to change, for example the rigid rejection of the metric system, all sorts of excuses why the old British system is superior and easier to use. Blinkers on, look straight ahead and deny.
That is easy to fix, anyone that you know can't be trusted with a weapon should be locked up or put down.
Military......... Constitutional "Well-regulated militia." Thi scan be both Police, (whom are citizens) AND PEOPLE.
Military servicemen have them in their home as can we..
Tell me why we cant...
This is your guy never convicted, has weapon, ends life with taking others out. It's sad.
And it is not the AR's fault, nor AK, favorite poster gun of the anti-gun.
But is this relevant in the 21st Century ? ....
Yes, it is.
As long as there are men, there will be tyrants.
And just because the tyrant professes good intentions, doesn't make him any less a tyrant.
Originally Posted By: raaizin
Call me crazy, but I truely believe if the press would NOT name these cowards and show their pictures on TV/Newspapers there would be less of these incidents. I know this will never happen but just a thought. Does anyone agree with me?
I don't know if there'd be less incidents, but the media is out of control. Wall to wall 24/7 coverage with nothing but speculation surely doesn't help the situation.
