Picking up this John Deere D125 with 218 hrs on it from a friend for $150, deck is rusted out but its perfect for what I want to do with it, move small trailers around the property and other stuff. Is this the Intek engine that is known for head gasket failures? They made these mowers from 2014-17, I plan on changing the oil with M1 15W50, new plugs, air filter and fuel filter, also removing the TuffTorq hydrostat to drain the fluid and put fresh fluid in. Ive read anything from M1 15W50 to john deere low viscosity hygard can be used.
Also just for fun, if possible, can the engine pulley be swapped out for a smaller one to make it faster? Looked on youtube but not sure if its possible with a hydrostat transmission.
