John Deere AM125424 Cut Open
DELAWARE
Have for your amusement a cut open John Deere AM125424 oil filter that was in service for 50 hours on my Cub Cadet with the Kohler 22HP V-Twin motor. Oil used was Delvac 1300 15w40. This is a pretty tight filter with 78 pleats I counted with a crimp seam. Has decent open louvers with also a silicone ADBV (verified by burn test). Filter is marked Made in Brazil. Only detriment is some rust pitting on the inside dome end. Filter was order from Amazon and appeared to be fresh stock.
In went a Lube-Finer PH3656 shorty OPE filter with Delvac 1300 15w40.
