Originally Posted By: dkcase
In the Jeep Liberty world, in the Forums I check, that transmission is described as a lighter-duty unit than the 45RFE that was used in the 02 and early 03 Liberty. We have an 02. At the same time, there is not a record of posters saying their transmissions failed.
I have concluded if it is indeed a lighter-duty unit, it must be strong enough. Whether they switched to it for an engineering , or cost-saving, or availability reason, I can't say.
One complaint I have seen it that they say they have had trouble backing up a hill (? !). Some had to give it a lot of gas, others shifted into 4-wheel drive, if I remember right.
I have the same complaint with Reverse in my 08 Liberty, seems it needs a lot of gas to go up hill in Reverse. It also felt like there could also be a slight shudder going up hill in reverse, but I can't get it to do it again. I thought it could be that the gear ratio for reverse is a little higher than 1st would be for Drive.
What auto transmission are they using in the 08 Liberty?
Thanks,
Frank D
