Jack stand pad help
South Carolina
Hi all. I just picked up these jack stands and then realized I’ll need some “pads” for the pinch weld. I haven’t ever seen jacks like this before. Anyone use something like this? What pads did you use?
Link: https://a.co/d/04w2ESpS
I've used those without any pads on certain cars like BMWs which have rubber pads already. Others that have pinch welds, just cut up a 2x4 or a piece of scrap wood.
When the factory jack lifts up my Subaru the lifting force is not on the pinch itself but on the edges above the pinchweld. The pinchweld just kind of holds the jack in place.
The adapters you can buy seem to put the lifting force on the pinchweld.
The best jack pads I have are pieces of conveyor belt I have from work. They are 3/8 thick and I cut them in 4x4 and 6x6 squares. If you can acquire any conveyor belting pieces they work great. They don't slip at all and don't mar anything.
  • Like
Reactions: D60
Any jack or stand you use should match the factory jack for fit and location.
The factory (pinch-weld locations) is reinforced to prevent damage.
If I damaged the pinch weld area, that's just sloppiness.
That has been my experience as well.
I've been using these jack stands for over 20 years on my Toyotas, Mazdas, and BMWs. The first two use pinch welds and in moments of laziness I have just put the pinch weld directly on this kind of jack, without a block of wood. Not really a big deal.
Of course in my area, we are not barbarians who salt roads, though.
  • Like
Reactions: D60
