For $7.50 you can get 5 quarts of Maxlife at Walmart.
Quote:
...Unless WP is rebottling havoiline, pennzoil, etc. into their own, you can be sure that there is a difference, and likely a $1+/qt difference in the chemistry - chemistry sure aint cheap.
Quote:
Quote:
Look at the rating on the oil. If they meet your needs then the oil is a candidate. SM meets SM standards, period.
Things can be engineerd to be 'good enough', or better, and still meet a standard. A battery of tests, regardless of how tough they are, and how 'PC' the grading scheme is, can be passed with varying degrees of success. Unfortunately something like 'SM' lumps the super great ones with the barely passed ones... At least something like ACEA A1, A3, A5, etc., while each test is tuned to different things, lets a hierarchy of abilities and performances fall about. Companies can design to one or many... and buyers can read into what each certification means regarding the robustness of the oil.
JMH
Quote:
Quote:
I don't use supertech because I don't want to create a big problem by saving $5 on an oil change. That said I have a friend who uses supertech dino 5w30 in his Chevy Blazer and it went 285000 miles before he traded it in on a new Nissan. The Nissan gets ST every 4000 miles at WalMart. SO are we all fools? I sometimes wonder. FWIW, he changes his Fram air & fuel filters every 50,000 whether they need it or not and the trans oil every 100,000. Never touches the transfer case or diffs.
I hate people like thatThe reason is they are probably correct and smarter not to mention they probably sleep better....if I did that I'd stay up with worry![]()
But I'll never use WM dino ST....or will I??![]()
Quote:
Before you take this wrong and bash me....Remember I do agree with you![]()
Quote:
Cost effective, yes. Best you could have bought, no.
Good enough to serve the purpose, yes.
Quote:
What I can tell you is this. If you run ST convential and change at 3,000 miles your engine will outlast the rest of the car. If you run ST synthetic and change at 6,000 miles the engine will outlast the rest of the car.
Enjoy the day!![]()
Quote:
I concur... but then why do we make thousands of posts at BITOG???![]()
JMH
