Is this a PAO based synthetic?
Kuwait
I'm looking at the MSDS of the 5W-40 I'm running in my Montero. The breakdown is as follows:
- Lubricating oils (petroleum), C20-50, hydro-treated neutral oil-based: 50-75%
- Polyolefin polyamine succinimide, polyol:
- Phosphorodithioic acid, O,O-di-C1-14-alkyl esters, zinc salts: 1-2.5%
- Phenol, 2,2'-polythiobis[4-C8-30-alkyl derivs., calcium salts, overbased:
To my understanding, polyolefin polyamine succinimide is a friction reducing anti-wear additive, whilst the alkyl ester is ZDDP. But what is phenol? Considering polyolefin polyamine succinimide is mentioned, I take it this is a Group III based lubricant?
Thanks!
Just had a look at the German PDS where "Synthesetechnologie" or "Synthetic technology" is used to describe the product, so I suppose it is a Group III afterall.
Can someone please explain what phenol is though? Thanks!
Phenol, also known as carbolic acid, is an organic compound with the chemical formula C6H5OH. It is a white crystalline solid. The molecule consists of a phenyl (-C6H5), bonded to a hydroxyl (-OH) group.
The word phenol is also used to refer to any compound that contains a six-membered aromatic ring, bonded directly to a hydroxyl group (-OH).
Straight from Wikipedia.
Without the cas #, looks like a group II/IV blend at best, but most likely a "conventional". Really though, "Conventional" doesn't exist anymore since most ilsac lubricants employ higher group hydrotreated base stocks. What's the VI and NOACK?
Thanks for the input! Now it makes a lot more sense.
Viscosity Index is 176, although there's no mentioning of NOACK. That said, the CAS numbers are:
- Lubricating oils (petroleum), C20-50, hydro-treated neutral oil-based: 72623-87-1
- Phosphorodithioic acid, O,O-di-C1-14-alkyl esters, zinc salts: 68649-42-3
- Phenol, 2,2'-polythiobis[4-C8-30-alkyl derivs., calcium salts, overbased: 90480-91-4
The labeling also just says "Synthetic" as opposed to "Full or Fully Synthetic".
Quote:
Detergents (Surface Protective Additive): metallo-organic compounds of (sodium, calcium, magnesium, boron) phenolates, phosphates and sulfonates such as alkylbenzene sulfonic acids, alkylphenol sulfides, alkylsalacyclic acids; Lift deposits from surfaces to keep them suspended.
