This is about the 2001 Dodge Dakota in my signature. 3.9 liter V6, 5-speed manual, just shy of 164,000 miles on it now. Recently I started noticing a burning oil smell when I park the truck after driving it. I changed the oil yesterday and did not see any leaks underneath. Today I got a better look at it and I have oil and greasy gunk all along the lower edges of both valve covers. The right valve cover has a breather tube grommet with a hose leading to the air intake hat on top of the intake manifold. My truck does not have an EGR system.
Today I drove the truck around the block, got home and noticed a thin stream or flow of oil coming out from the bottom side of the breather grommet. So I know I need to replace it. The PCV is brand new, I replaced the hose that leads from the PCV to the intake about a year ago because it was cracked, and the PCV grommet is clean, there is no oil or gunk coming from it. However the left valve cover looks pretty much the same as the right, it has oil and dirt collected along its lower edge and there are oil spots on the exhaust manifold just below.
Check out these pics of the right side valve cover. Does it look like they are leaking too? I did see greasy spots and what looked like oil spots on each exhaust manifold, which also makes me think I have bad valve cover gaskets. It's not leaking enough to smoke but it does smell bad like burning oil when I park the truck, and I have also noticed the smell at a red light when I have the window down.
As always, thanks for your help on this.
