Is there a 0w20 syn blend?
Valvoline MaxLife
There are a LOT of synthetic-blend 0w-20 out there. The problem is that there is not a lot of off-the-shelf blends and they are distributed to the dealership/repair and quick-change shops. However, I can get NAPA 0w20 "Synthetic" for $3/qt so why look for a blend at the same pricepoint since "Syn-Blends" are marketing terms ONLY!
Heck, even Havoline makes a 0w20 synblend. Good luck finding it.
http://www.havoline.com/products/motor-oils3.aspx
If grpIII is not synthetic - then MOST of them are blends.
"Fully Synthetic Motor Oil" is a marketing term ONLY per API documentation.
Not a performance term.
Originally Posted By: FordCapriDriver
I think i've seen a mineral conventional 0w20 somewhere
I don't think it is possible to achieve 0W performance with a straight conventional oil.
Not true.
The Grp III designation is based upon an arbitrary cutoff of basestock VI, 130 minimum IIRC, so it is a performance standard.
The ILSAC/API spec states what I wrote.
I wasn't addressing VI of basestock. Vi is not one of MY Top 5 criteria for good lubrication in temperate climes; granted vi does in large part define multigrade performace for winter usage.
Motorcraft
https://www.fcsdchemicalsandlubricants.c...ory=Motor%20Oil
Kendall
http://www.phillips66lubricants.com/documents/Kendall/engine_oil/Ken%20GT-1%20High%20Perf%20Syn%20Blend%20MO%20%28Ti%29%20TDSw%20815899.pdf
76 Super
http://www.phillips66lubricants.com/docu...Sw%20778615.pdf
Castrol
http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/8D1D0BDE9CD081CC80257AA900533A56/$File/GTX_SynBlend_2012.pdf
Havoline
http://www.chevronlubricants.com/en_US/products/products/havoline-synthetic-blend-motor-oil.html
