Originally Posted By: StevieC
Originally Posted By: tig1
A good synt. like Ams, Mobil 1, Pennzoil Platinum will be a better lube at 10,000 mile OCI than conventional at 5000 miles.
Tig1 is probably right, but seeing all the engine internals I have seen run on yesterdays spec conventional oils for far longer OCI's than they should have been and watching them all survive into the "high mileage" category I would have to say that conventional is pretty much fine for 99% of the vehicles out there IMO.
That said I run a syn because my engine has a cranky leprechaun in it that lets me know he isn't happy when its cold out. If he didn't come with my SUV I would be using conventional and an Amsoil EAO filter.
Now in Turbo, high performance, high output, or extremely high heat (not talking about driving in Texas summer weather) applications I would go with a Syn as recommended by the manufacturers.
Truth is there is millions of vehicles on the road that see nothing but questionable quality bulk conventional usually in the wrong weight as specified by the MFG, or the climate conditions and questionable filters with over extended OCI's under severe duty conditions and yet they still manage to last a very long time...
Marketing from the oil companies would have you believe otherwise.
I'm going with Stevie on this one.
The only reasons I use Synthetics:
1.) Wife is tough on cars. Helps me keep it running longer.
2.) MI has some crazy weather and people around here. It just pays to be prepared.
3.) I plan on running them into the ground.
For what amounts to maybe 50 bucks a year difference, it's just worth it.
