BrokenAudiTT Joined Apr 21, 2025 Messages 34 May 5, 2025 #1 I have several quarts of this oil with a 98 date stamp. It's still good right ? Last edited by a moderator: May 6, 2025
S spasm3 Joined May 30, 2010 Messages 18,683 Location North Carolina May 5, 2025 #2 I'd use it only in a mower.
Lawnman23 Joined Sep 20, 2023 Messages 816 Location Minnesota May 5, 2025 #3 SJ is spec’ed for 2001 and older. If still sealed, run it if applicable for something or for OPE as mentioned.
BrokenAudiTT Thread starter Joined Apr 21, 2025 Messages 34 May 5, 2025 #4 I think I'll just take it to be recycled
5 53' Stude Joined Mar 12, 2015 Messages 36,495 Location In the shop May 5, 2025 #6 BrokenAudiTT said: I have several quarts of this oil with a 98 date stamp. It's still good right ? View attachment 277657 View attachment 277658 Click to expand... Use it in OPE
J JimPghPA Joined Aug 22, 2009 Messages 7,448 Location Pittsburgh,PA U.S.A. May 5, 2025 #7 Actually, LSJ pointed out that one of the additives that settles out of old oil and no longer works is for not foaming up. A sump full of bubbles is not a good oil, even for an outdoor air cooled engine. I would use it for chain lube of a chainsaw, and nothing else.
J JohnnyJohnson Joined Oct 22, 2009 Messages 9,857 Location Wet side WA May 5, 2025 #8 I've been using that kind of oil in my mower for nearly 20 years now. So it hasn't been bad enough that ole air cooled Briggs has given up the ghost
E Escape08 Joined Mar 10, 2021 Messages 1,615 Location TX May 6, 2025 #9 If you have a late 1980s - 2000s vehicle. You can pair it with current 10W40 with 25:75 mix ratio or 1 qt : 3 qt (current) if the engine requires 4 qts of oil
F Fordiesel69 Joined Sep 10, 2005 Messages 2,817 Location Erie, PA May 6, 2025 #10 In any case I do have a small vintage oil collection. I do not use old 60's, 70's ~90's 2 stroke oils. They are just for viewing pleasure. The chevron supreme 10w-40 pictured would be fine in an old lawnmower engine, or as bar and chain oil. Not good to use in a car engine.
A addyguy Joined Sep 8, 2005 Messages 16,604 Location Canada May 6, 2025 #11 I’d use it in a car engine no problem. We’ve seen used oil analysis using super old oil in newer engines, and it does just fine.
Lockasiam Joined Oct 28, 2024 Messages 496 Location IN May 6, 2025 #12 JimPghPA said: chain lube of a chainsaw, and nothing else. Click to expand... can you add tackifier?
F Fordiesel69 Joined Sep 10, 2005 Messages 2,817 Location Erie, PA May 6, 2025 #13 yes, 4 oz of STP / motor honey will go a long way.
