Decided that since it was a balmy 55F I'd contemplate a drain and fill on my Tundra. First things first, break loose the fill bolt and the check level bolt *before* touching the drain bolt. Those moved, but the oil that came out of the check level was... as pink as could be. I'm thinking I can just soldier on since it's pink and not some shade of black. Seem reasonable?
Vehicle in question:
I bought this Tundra used at 73kmiles, presumably with no prior trans service. I did not find any evidence of towing nor big dents in the bed, so it's possible it lived an easy life. It holds 12qt and at 80k I was able to change about 7qt with Maxlife. [At that time I dropped the pan and cleaned the magnets--very little metal--and changed the screen--no garbage that I saw.] Truck rarely sees short trips, used mostly highway, no towing, infrequent heavy foot driving. I'm thinking with 30k "easy" miles I hardly need bother with a drain and fill. Especially since the stores are closed today and I forgot to buy a length of hose to refill, and don't want to spend 15 minutes using a hand operated transfer pump.
