"All" the mechanics told me it was a cat code. They said it had nothing to do with the O2 sensors????Switch bank 1 and bank 2 O2 sensors.
The man is onto this cheat. In Texas the licensed inspectors at the licensed inspection stations are instructed to look for anti-foulers and flunk any vehicle it is found on. Some inspectors look, and some inspectors don't look. Once they flunk you the vehicle is tagged in the state's computer and you can't get an inspection passed anywhere else until you have the problem properly corrected.I used the spark plug antifouler fix on my ‘96 vortex pickup without cats. Works like a charm, no cel’s in over 1000 miles.
Depending upon how quickly the code returns if the spacer is absent, you could conceivably drive around with the spacer....this would keep CEL off for your personal sanity but still allow drive cycle counts for inspection. Then pull spacer before inspection.The man is onto this cheat. In Texas the licensed inspectors at the licensed inspection stations are instructed to look for anti-foulers and flunk any vehicle it is found on. Some inspectors look, and some inspectors don't look. Once they flunk you the vehicle is tagged in the state's computer and you can't get an inspection passed anywhere else until you have the problem properly corrected.
Now that it’s been a few months, how is the catalytic converter situation now?Update on my codes.
I ran 2 cans of Cataclean with 1/4 tank of gas. I was on my third fill up after the Cataclean and the
lights all went away. I ain't kidding. I didn't erase them. I was driving and looked down and the pretty lights were all gone.
I'm keeping my fingers and toes crossed. I even checked my Blue Driver and I don't have any "pending" codes.
My mechanic said it may take a couple of fill ups before I would know if the Cataclean worked. Maybe he is right????
I know a guy who installed one of these on a very high mileage vehicle. His cat plugged so he rodded it out and that turned off his light. Prior to that, he had tried spacers with no luck.There are also O2 sensor "extensions" that have a small catalyst in them. These also seem to work.
CEL Check Engine Light Adapter CEL Eliminator Mini Catalytic Converter O2 Sensor Generic
Feature:1: The O2 CEL fixture actually incorporates the M18X1.5 miniature catalytic converter,which helps to get rid of the modified exhaust or the inspection engine light after removing the catalytic converter.2: Made of Zinc Plated Steel which is durable and have high strength to use.3: AVOID...ucarpart.com
That code means that the cat is not cleaning the exhaust as it should. 90% of the time it's a failed cat. But it can be caused by other problems like a vacuum leak or bad injector.
Cat was replaced. All is well.
Lol. There will never be a cat in my house.
If you were allergic to cat dander, you’d understand. I didn’t know how “nasty” they are until my ENT Dr explained it all to me.
Yes! When l worked at the tune-up shop{s} in PA circa mid 80's we did emissions, but the program was brand new in PA.Since the cat does not have any electronics in it there has to be a sensor that reports the problem, so there is always a chance that the sensor is reporting false info. Pick the easiest , cheapest one to replace first unless you have away to test the sensor. But I would do as suggested and take a good long drive to get it hot and then clear the code to see if it comes back first.
