Is occasional red-ling of the tachometer (or high revving) good for engine or keeping the revs 3000rpm max better?
Happens all the time when a kid gets a nice-looking used car and takes her out for a spin on the Autobahn, or if he drives with high RPM. I've seen it happen a few times to friends of mine -- when we were young and dumb.quote:
The increased stroke caused by the stretching of the connecting rods by this suddenly increased RPM's causes the pistons to travel a few thousands of an inch further up into the cylinders, and the rings hit this wear ridge, thus causing them to break. Theoretically, I suppose it's possible. However, I doubt it's something that actually happened.
I-80 in Nebraska and Wyoming.quote:
When can you ever set the cruise control to 75 and drive for 500 miles?
The rolling roadblocks in the left lane just about guarantee you'll have to pass 'em on the right.
That's why you should flog it on the test drive before you buy it!quote:
If you buy a used car that was never driven at high RPM, guess what happens if you decide to flog it?
Good explanation, thanks.quote:
I am no engine expert but from what I have always been told the engine bearings are ecentric, not concentric.. meeaning they are slightly out of round to accomopdate a thick fluid wedge on the loaded side of the bearing. By runnning the RPMs up with no torque there may be parts of the bearing that are not constantly under hydrodynamic lubrication if the intended load is not applied. Your engine only produced enough torque to move the load, no more despite its ratings. So as long as you are moving the car it is producing some torque wheich should be good enough.
I lament that after I top out second I am beyond legal too.
I always thought the logic behind varying the sped during the first 500 miles or so was to generate vacuum (during the deceleration phase) to pull some oil up onto the cylinder walls. This helps lube the rings so that they can seat better.quote:
I've always heard one shouldn't drive at a steady speed/load/RPM for the first 500 miles
