I have a 97 z28 camaro and I just replaced my water pump. I pretty much got all the fluid out of the car includint the block. Well everything went ok and i filled it with peak lifetime 50/50. I put two gallons because thats all i had and it appeared that i needed just a little bit more fluid to run the car. So i put in half a gallon of distilled water till i got some more. I then bought full strength peak lifetime and added a half gallon of that. So i have a 50/50 mixture.
I bled the system out good and used my hydrometer. Its got 5 balls in it and only 2 are floating. The rest arent floating but they aren't sunk completely to the bottom either. It says if 2 balls are floating only protected to +5 degrees F. I've already went down past 0 and it hasn't froze. I was wondering if my hydrometer is right or wrong and if i am safe for now? Worst temp i think ill have this year is -20 F w/ windchill.
So, should i add some more antifreeze or not? Ive used 50/50 water with dexcool and it floated 4 balls previously but that solution was full of dirt so i dumped it.
