Originally Posted by JHZR2
Originally Posted by supton
Can you put in a borescope that is backlit?
Can you test for wear if you set the parking brake? I'm wondering if the lash can be felt in the driveshaft while elevated--although this could be bearing wear and not from teeth. But still.
Can you explain this test more?
This car squats and raises much less than my 240D when going from reverse to neutral to drive.
But I don't think that's lash.
In park I cannot turn the driveshaft by hand even just a slight fraction.
My thinking is, in neutral, feel how much slop is in the pinion, either rotationally or side to side. Probably easier if the wheels are locked. Not sure if the manual lists limits.
