Patman, a 0-40 can flow better in cold than a 5-30 because at extremely cold temps. -30 - -35C it's thinner.
But at 40 C and beyond...eg. 100C, it's thicker. Remember, 40C is 104F...hot! Both 40 and 100C are hot. Therefore, it's an oil with a WIDER range. It simply doesn't thin out as much as a 30 weight when hot.
As far as the M-1 15-50, it's basically twice as thick at 40C than the 10-30. True, the pour point is the same. This is because the pour point is simply the point at which there is NO movement of an oil on a vertical surface for 5 seconds. Doesn't mean much. Basically it's thick all the way through the temp range...and still exibits movement at -49F whereas the GTX doesn't. So don't go by the pour point numbers...they're not the complete picture regarding cold performance. The pumpability numbers (when posted) are. The cold cranking numbers for a viscosity comparison at a specific temperature....eg. at -25C M-1 15-50 is 14,050 cP and the 10-30 is 3,848 cP and the 5-30 is 3600 cP at -30C!! The 5-30 GTX is probably in this range...because these are the SAE/API requirments for these grades...not the pour points!
So a 5-30 will always outperform a 15-50 in temps below -20C regardless of pour points...it's just below this, the GTX 5-30 will 'freeze' sooner...ie. at -33C vs. -45C (not -37C as you posted-this is the pump. limit).
This can probably be deduced as a "safety margin" we have with synthetics...ie. they can still work at temps. below where conventionals will freeze. Hence, the pumpability for M-1 15-50 is advertised as -37C!
