Originally Posted By: NHHEMI
T-IV/3309 has been around for a long LONG time. It is nothing special whatsoever.
Don't get too carried away there.
My Saturn dealer told me to put regular Dex/Merc in my Vue (Aisin 5 speed).
Quite a bit later, I figured out it was supposed to have T-IV. Up until very recently, everything seemed to be fine with the Dex/Merc.
The first drain/refill was with Pennzoil YB Dex/Merc.
The second drain/refill was with Valvoline Dex/Merc. It lasted about 7 thousand miles before it was causing problems.
In the thousand or two miles between that post, and when I flushed it to I-IV, things changed. At first, the shift points moved. My wife noticed it would rev higher before shifting. She noticed this because she drives very gently, and rarely saw the tack go up. Then one day she called me at work to say it wouldn't reengage for a seconds after a shift. She let off the accelerator and coasted a bit, then tried again and it went.
I did a cooler line flush running 10 quarts of Toyota T-IV through it, and it is back to normal.
The first drain/refill would have left about 50% T-IV. The second would have left 25%. I'm guessing that either 75% dex/merc was too weak, or Valvoline's isn't as sturdy as Pennzoils.
From everything I've read, T-IV seems to be a bit heavier duty version of Dex/Merc. So while there may not be anything mysterious about it, one should be careful what they use in place of it.
BTW, My local Toyota dealer sells their T-IV for $4.32/qt.
