Originally Posted by vw7674
Originally Posted by BMWTurboDzl
Originally Posted by burla
So redline 5w30 is known to be a tick killer, no oil like it that I have seen and for those interested we have tested many. One particular case redline wouldn't kill the guys tick, his application was 40 weight, and he added liqui moly mos2 to his redline run and the tick was killed. So overrated, depends on what you are using it for. We do believe this guys issue was piston slap and not lifters as it was a cold thing only, but clearly it worked.
The customer should pull out all the MOS2 which sank to the bottom of his oil pan and re-sell it.
I was thinking the pistons expanded as the engine heated up & killed the cold piston slap.
But whatever.
He had the piston slap with every oil he tried, redline quieted significantly but he still had pisten slap especially yes when cold, he lives in the U P, so snow belt. However, the point is he added the mos2 kind of out of the blue and had no piston slap, not even in the cold. Take it for what it's worth, I know the guy he is a friend, so I believe him 100 on it. He is still doing some more testing, different redline's have different effects as we see, for example the 0w40 and 10w40 do not kill tick as good as 5w40, it's just a thing reported by many 6.4 owners. Same holds true with 5w30 versus 10w30 or 0w30 for whatever reason the 5w30 redline does the best as noted by like 1/2 the forum over there. More testing needed with mos2, but when asked if it is over rated by OP, I guess it depends if you are just going off used oil analysis or maybe trying to quite some start up chatter. I have one example where it did so, in that case not over rated imo, just what the doctor ordered. Still curious if the moly slimes up those spots, then maybe long term there could be issues, dont know, but I know it quieted down this slap in this instance.
But whatever.
