I installed my Home Depot catch can this past summer on my '97 Maxima. Mine was made by Campbell Hausfield I think. I have run it with and without the filter stone, and really can't tell a difference in volume of what is caught. I can definitely tell the difference between Castrol GTX 5w30 and GC, though. It is very repeatable, and I even keep track of it in my mileage spreadsheet. I marked my plastic can at 10ml (.338 oz?), and check it often. With GTX 5w30, I'd get to 10 ml in about 300-350 miles or so. With GC, it takes 550-600. I'm not sure why there's a difference, unless it shows that GC is less volatile than GTX? My driving habits are roughly the same. I was however doing an Auto RX treatment while using the GTX (both phases). I installed the GC after the rinse phase. I guess this could be another factor in volume it is catching, but I'm not sure.
Also interesting, is this past week or two the temps at night have finally been getting cool (low 50's). In the heat of the summer (never below 75), the gunk it caught was just really black oily stuff. I emptied it yesterday, and the gunk was a chocolate milkshake color, and the bottom of it appeared to be water. I mixed it up, and it settled back out, with the oil floating on the water. I poured it on a paper towel and tried to light it, but it would not catch fire at all. I attribute this to the cooler temps at night allowing more condensation in my engine, and the catch can is catching it. This would definitely be a plus. Or I have thought that maybe I have a head gasket leak, but don't know if it could cause this. I don't have any symptoms of a head gasket leak, though. Has anyone else noticed this with dropping temps?
I was very limited as to where I could mount it and still have decent access to it for emptying. A buddy gave me a large roll of 3/8's stainless steel tubing and some stainless compression fittings with the 1/4 NPT threads (I think that's the standard for air compressor stuff). I installed the catch can behind my passenger headlight, and spent hours bending the stainless tubing with a tubing bender. It took awhile to run the tubing where it would still appear "stock" (or about as stock as it could get). Did I mention it took hours to bend it all just right? But the end result is well worth it. I originally had used 3/8 fuel line, but it looked really out of place. My buddy saw it, didn't like how "monstrous" it looked, and gave me the stainless tubing with a tubing bender. The stainless has a much thinner overall diameter, while having the same inside diameter. It's much stronger, so no chance of a rupture or it collapsing. It's also impervious to any fluids, easy to clean, and just looks really nice. I did use about 4-6 inches of rubber emissions hose at the engine ends to allow for movement. I didn't think it would be good to have it totally rigid and be stressed by the engine rocking. It took about 8 feet total to plumb it where I've got it. I also fabricated a small bracket to mount it to my inner fender instead of using zip ties. I thought it would make for a cleaner install.
I've since seen pics of other Maxima's with it mounted in a different spot (near the passenger firewall), and may check in to relocating mine there. My main concerns would be accessibility for draining, and engine heat preventing the gases to condense back to liquids. Anyone have any thoughts about that?
If I knew how to post pics, I'd put some on here to help with the discussion.
Hope this helps.
Dave
