The factory engineers put a MAX line on the dipstick for a reason. Why do so many people think they are smarter than the engineers?
They must be watching Fox News.
I think Ford Engineers need to watch Fox News. They would make Care that -work- instead of giving ford its 80s Acronyms.
Besides, a little extra oil (Half quart or less, i agree) will Stimulate the Full Lubrication ability. Anything MORE than that over-full, and i believe you are causing the engine to run Hotter?
I always either one of two things:
1) Round UP a Half quart, because NOBODY has mentioned the Oil Filter so far.. and some people have told me that some Oil Filter placements make them not that effective, and its not really getting a lot of Oil through it;
OR, if im feeling Mechanically inclined for some reason...
a. Add all but One of the Recommended Quarts of Oil. (Car needs 5, add 4. Car needs 6, add 5. Car needs 8? add 7. Like Corvette, Jaguar, and other large-sump cars)
NOTE: IF YOU HAVE A 4-cyl HONDA CRX, JUST ADD 4 QUARTS 5W-30 AND THATS IT.
b. Put Dipstick Back, Put Cap back on )BOTH should be off when draining Oil for maximum Drainage of old Oil, take Cap and Dipstick out.)
c. Start Car, let it run for 30 seconds or so. (This whips it up and Circulates it. Only a little amount of time is needed.)
d. Take Cap off again.. and Add one-half to Full quart of Oil.
This is the Financially Responsible, 100% Constitutional, Real American Technically Detailed "Fox News" approach to get that level very well.
Check again after 10 minutes or so, as this was ALL the Oil dripped out of Head.. didnt really get up there in the First place, but this is the New oil you are checking, so, should be as pretty close to accurate as can be. (Similar to the "M104 Mercedes Benz" approach.)
Oh.. If possible, do on a "Warm" Engine, or one that has sat for 10 to 20 minutes after using it for the day.
