Is It a Good Idea to....
Brooklyn, NY
I have a 97 Avalon with the 1MZ-FE a know sludger and I do not want to have to change the oil for the remainder of the winter. Is it safe to run something like Pennzoil Platinum for like 8k miles in this engine or am I pushing my luck?
Change your PCV valve and you should be able to make it through the winter on normal. PP is fine but if an upgrade would give you peace of mind, go with PU, EDGE, or Mobil 1 Extended Performance. If you don't mind the money, try RP, RL, or Amsoil.
If you change oil& filter, PCV, right after Thanksgiving, won't the mileage/months put you through the NY winter and allow you to change on a warm March day? It's what I try to do. Same car.
I would not be going longer than double the severe service interval with a quality synthetic, so about 6000 miles with PP should keep you sludge free.
I agree. Why tempt fate in a known sludger?
Because we at BITOG believe we've figured out why it sludges.....
