In Washington State, though? @ripcord mentioned that they recently banned the sale of any AC refrigerant.
R152a is also known as "canned air".
Crap, really? I'd hate to have to do that, we already rebuilt the front end...The conversions from R12 to 134a usually aren't as efficient because the condenser in an R12 unit is too small. If you can retrofit a 134a-designed condenser in place, it will work much better.
Hydrocarbon refrigerants; you mean that Frostycool or Envirosafe stuff?I would agree. Ive had 134a retrofits done before, but to get it right, a better condenser is really necessary at minimum, and the results aren’t always up to par.
Hydrocarbon refrigerants really are great. I use them for troubleshooting leaks since they’re easier to get than bone dry nitrogen laced with r-22. Case in point my 1982 MB 300CD. Runs R-12 but lost charge when sitting many years after our first child was born. I vacuumed the system and used HC for the test.
That was 2020. I haven’t repaired the oring leak. The AC still blows cold on that HC charge today in 2022… despite the leak. The whole thing about bigger molecules not leaking as fast is real!
Well that shouldn't be hard to find, lol. But how would I get it into my AC system? And what about oil?R152a is also known as "canned air".
Envirosafe. Ive used both the regular es-12a and the industrial. I prefer the industrial because you can charge it into a vacuum…Hydrocarbon refrigerants; you mean that Frostycool or Envirosafe stuff?
Ok. But @brianl703 said that federal law makes it illegal to use that to replace R12...oh wait...is this the part I'm not supposed to mention out loud?Envirosafe. Ive used both the regular es-12a and the industrial. I prefer the industrial because you can charge it into a vacuum…
If I'm gonna do that, I might's'll use R134...Well if you convert it to R134a FIRST...
That rollguy that respond to your thread is my neighborI would agree. Ive had 134a retrofits done before, but to get it right, a better condenser is really necessary at minimum, and the results aren’t always up to par.
Proof:
Leaking Expansion Valve? - PeachParts Mercedes-Benz Forum
Ya think? I bought my 300cd a decade or so ago, and I knew it had some history of AC leaks. I have all the receipts for the life of the car. But itwww.peachparts.com
Wait, so if I just did the bare minimum- dryer/accumulator, o-rings and adapters, would I be good for using a hydrocarbon refrigerant? I don't want to have to replace the condenser if I don't have to- finding one and then retrofitting it would be a pain in the neck that I don't want to have to deal with right now.You could try it and see how it works. If the performance of R134a is not satisfactory, you can then convert it to an HC refrigerant.
But there's also the legal stuff- I don't want to be doing something that isn't legal in my state...
Pretty soon your state will make IC cars illegal as well. I doubt the HC police have hidden cameras trained on your car to catch you install some illegal substances.But there's also the legal stuff- I don't want to be doing something that isn't legal in my state...
True to a point. The HC if done right will have lower pressures and better cooling for the same condenser cross sectional area.If I'm gonna do that, I might's'll use R134...
I believe that’s called a “sham retrofit”. The actual ramifications of doing one, especially DIY and at this point after all these years? Likely nothing. But just know the situations.Wait, so if I just did the bare minimum- dryer/accumulator, o-rings and adapters, would I be good for using a hydrocarbon refrigerant? I don't want to have to replace the condenser if I don't have to- finding one and then retrofitting it would be a pain in the neck that I don't want to have to deal with right now.
So if I leave the old condenser in there, it'll perform better than it would with R134?True to a point. The HC if done right will have lower pressures and better cooling for the same condenser cross sectional area.
Ok. And that's legal, right? ...ish? I do want to do a pressure test under normal operating pressure, since my test with about 80PSI of air and a spray-down with soapy water probably wasn't the most effective.@JHZR2:
From my perspective doing just what you say, then using HC to pressure and operationally test the system is the best move. Vacuum and pressure testing are necessary, and getting bone dry nitrogen with a trace of refrigerant is more hassle than it’s worth, when you can be testing operationally with a can or two of HC.
Test it at 150-200 psiSo if I leave the old condenser in there, it'll perform better than it would with R134?
Now I'm wondering if it wouldn't be better just to buy some freaking R12 off eBay and charge the system with that. I mean, that's what it was originally designed for, and if some EPA bean counter wants to check my system, that's what it would've originally used anyway. But that's probably illegal.
