Originally Posted By: LScowboy
have a 2000 Malibu with 4T40-E transmission (3.1 engine) with 155K miles and I believe it calls for Dexron III - I am doing a pan drop, and changing the filter out with new GM filter, and changing out the oil feed manifold proactively, as these are known to break around 150K miles.
Is it OK to use Dexron VI without a full flush? - I don't like to change ALL of the fluid in an older transmission that has not been serviced before, that usually doesn't end well.
Sure it does. Happens nearly every time I service a customer's transmission. Lots of neglected transmissions out there and I treat them all the same.
Originally Posted By: Trav
Don't bother with this drain and fill business, its a waste of time and money. If the transmission is bad its bad if its good and you are doing it as maintenance its no problem.
I run into this on a regular basis, the customer notices the transmission is not working like it use to, its slipping, shifting funny, taking a long time to engage, etc.
At this point the pooch has already been screwed, it doesn't matter if you do drain and fills the transmission is very possibly damaged and any method used will be blamed for damaging the transmission.
Doing the line off method uses the units own pump to exchange all the fluid and is perfectly safe when done properly.
Using a machine in powered mode (i have not seen one, only heard) or unpowered mode simply means engine on or engine off, it does not back flush the fluid in either mode.
Like i said i you are doing this as preventive maintenance why would anyone want to pay for 30+qts of fluid to change 12?
Do it right and get it done with one job. If the want to know how to do this properly just ask.
Dex VI is the correct fluid for this unit.
You've hit all the right points.
O/P- if it matters to you, I've got a '98 Malibu with the 4T40E that may or may not have been serviced when I got it at with 172k miles. It got Dex VI and works just dandy.
