Put some into my Moog sway bar end-links. Moog only suggests using a NLGI-2 grease, no further guidance. The Blaster is NLGI. I asked Blaster and they told me to ask the mfg of the sway bar links. I asked Moog, no response.
the Blaster heavy duty grease is a calcium sulfonate-based thickener grease and is a good grease, though from the factory I would presume they used lithium complex ? ,you should be able to mix these two greases (according to machinery lubrication compatibility chart) ,,or go buy a tube of Mystik jt-6 (red) grease maybe a safer bet to use. or use blaster red grease (lithium complex ) .
