Irony
I just went through something like this yesterday. Who knew that the air filter on a GM 3800 Series II engine would be so hard to replace?
It's morning but already hot, and I'm sweating. I undo two screws on the filter housing, but there's almost no room to pull the housing back. I get the filter out, but putting in the new one is a pain. Realigning the housing lid is another pain. And then the real agony starts, as I try to hold the lid shut while I fasten the screws down. Finally I use a vise-grip. After I finish that, with grimy and scraped hands, I find the owner's manual tells you to remove that rubber accordion duct leading from the housing to the throttle body to give yourself room. Ack!
And the PCV valve was no picnic either. I'm done wrenching in the summertime (which lasts nine months here, only to give birth to a too-warm fall).
Now, if you'll excuse me, I have to go dab more antiseptic on the scrapes and nicks on my fingers.
I use my hands as well, few times that I had to use the wrench was when an oil shop changed the oil (most likely dry gasket and super tight). If I do the change, I never have to use the wrench, I screw in the filter by hand, 1/2 to 3/4 of a turn past gasket contact with the housing. Works well for me and never leaked.
I learned that on my 95 Accord, as the space was tight and using the wrench (I had the strap type) was ackward.
oil wrenches are for wimps.
Originally Posted By: StevieC
Never a fool if you have the proper tool!
And always a fool if you hire the improper tool. . .
Good one.
