With short rates at 550 BPS and you at 600, your not going to get called.I can assure you Fidelity is BACPRB once you own it. But I know what happened, the old system did not accept "/"
Maybe. I don't really worry much about being called, because I never buy over face. That said with a convertible the terms are important, in this case not much worry of conversion
If short rates go to 100, that may change?
If your time horizon is 30 years, then that changes things also.
I definitely need to research the conversion. I think that's mostly an option for the owner, not the company - ie if there stock skyrockets the preferred owner can convert to common stock. But this is all new to me so possibly I am way off.
