Thanks for everyone's replies so far!
Originally Posted By: bobbydavro
Where is the pressure sensor?
No idea, I'm using an OBD-II reader to poll a PID that claims to be the oil pressure.
Originally Posted By: Shannow
Wondering why you are trying to determine if you have the correct viscosity by pressure versus RPM ?
I want to make sure the oil is not too thick (due to its higher HTHS value compared to other 5W30s).
Your OEM provides a minimum oil pressure recommendation as a maintenance intervention point for a worn engine on the recommended oil viscosity...
According to the
engine spec , the minimum hot pressure are 6 psig @ 1000 RPM, 18 psig @ 2000 RPM, 24 psig @ 4000 RPM. Is the gauge giving me psig or psi so I can do a direct comparison?
...others on BITOG who have literally zero understanding of hydrodynamic lubrication (flow equals lubrication in their world) have taken that minimum oil pressure as a target for viscosity choice...the fact that they get away with it does not make it optimum.
So, what should I be targeting then if not as a minimum?
Originally Posted By: A_Harman
Don't worry very much about the average oil pressure while running down the straights, worry about the minimum oil pressure while running through long turns at high lateral G's. Long left-hand turns in my Corvette lead to oil pressures of div>
I need to take a look at the log for the track session that I ran it the hardest. I'm working on doing some summary graphs automatically for any trip data and then I can quickly eyeball rather processing them manually, which is what I'm doing now.
I use Torque Pro, and it does have a setting to log acceleration. I guessing I want a field called G(calibrated) and not G(x), G
, G(z).
