Originally Posted by OVERKILL
When you are having this issue, open up a command prompt (Windows Key + R, CMD) then type ipconfig and see if you still have a valid IP address. If you do, ping the ip address of your router. Do you get a response? If so, it isn't your network card. If not, do ipconfig /release and then ipconfig /renew and see if it is able to renew its IP address.
If you can't renew your IP address, move the ethernet cord from the port you are plugged into on your switch to another port. Does the connectivity return?
If the connectivity does not return, go into the properties of your adapter again, give yourself a static IP address outside the DHCP scope, set all the other parameters accordingly (SNM, Gateway) and then see if you have connectivity. If no, then we can conclude that it most likely has something to do with the NIC or drivers.
So I was logged into my modum looking at settings, and I got the network glitch - couldn't communicate with the modem or internet. I'm on my phone typing this post.
I went into the DOS command window and did a ipconfig command. Shows "Media disconnected" for everything listed.
Did a ping 198.168.0.2 command and got sent and received packages. 192.168.0.2 shows as my IPv4 address, and is what I use to log into the modem. Is that the address to ping? I'm assuming so, and that addresd does show when I did the ipconfig command.
Did a ipconfig /release command and then ipconfig /renew command. Then did a ipconfig, and got the same results of everything showing "Media disconnected". Ping still works.
Swapped the Cat5 ethernet cable from the network card to port #2 on the modem and repeated the above commands, and got the same results.
Lost you OVERKILL on your last paragraph.
