2005 GMC Yukon XL Denali AWD with the 6.0L V8
Over 300k miles but oil changed regularly with Mobil 1, usually before the OBC recommends it.
The truck has started having an issue where oil pressure kind of meanders and then suddenly tanks to near zero at highway speed/constant load, and the dash says engine oil pressure low. Then as soon as that happens it shoots up to 40 PSI + and goes away for a while. And so the cycle repeats.
I just changed the oil with Mobil 1 5W-30 HM and FRAM extra guard filter 2 weeks ago. Tomorrow I am going to replace the filter again to rule that out (my thoughts being it perhaps has a restriction and goes to 0 PSI, then the bypass valve opens, hence the sudden increase in pressure - a shot in the dark frankly and worth $10 and 5 minutes of my time to replace).
We had a similar low oil pressure issue years ago (2-3+ years ago) that required replacing the oil pump. I did not do the work since I don't have the required lift at home, so I farmed it out to someone else. My fear is that it is needed again. Or that the oil pickup is somehow getting blocked. I THINK we used a Melling pump but do not recall for sure..
Obviously I checked the oil level and it's fine.
Any ideas? I am dreading having to remove the oil pan again to investigate considering what a PITA it is on this truck with the AWD front diff and so on. Considering the mileage, I might even think about driving it until it dies and then junk replace it with a used/junkyard engine with fewer miles... these engines were used in a lot of trucks right? So I shouldn't have an issue finding one for cheap?
Driving video illustrating the issue:
