Interesting Temperature-Viscosity Chart
Olympic Peninsula
Here's the recommended viscosity grades for given ambient temperatures for my 1991 BMW K100. This is a 1000cc, water cooled, inline four cylinder, with a four quart sump capacity.
Notice the complete lack of trust in multi-viscosity oils. They allow for it to shear back to its base viscosity. This is assuming mineral base and service grades SE, SF, SG.
SAE 20: -10 to 20C
SAE 30: 0 to 30C
SAE 40: 20 to 50C
SAE 10W30: -30 to 0C
SAE 10W40: -30 to 5C
SAE 10W50: -30 to 10C
SAE 15W40: -20 to 20C
SAE 15W50: -20 to 30C
SAE 20W40: -10 to 30C
SAE 20W50: -10 to 40C
Ed
Ed
Huh? I see 7 different multiviscosity oils listed. They all apply to a temperature range that's equal to or (usually) greater than that listed for the single-vis oils. I'd say your conclusion is exactly backwards.
I agree somewhat with your "They allow for it to shear back to its base viscosity" statement, but you leap too far in your statement IMO. Certainly the viscosity-index improvers (VIIs) used in most Dead-Dino and some synthetic oils can get shortened ('sheared') and then do not as well at thickening at higher temps, but I simply wouldn't jump to your conclusion. I have seen used DD oils that have lost a degree of hi-temp rating, for instance a 10w30 having a 20-vis hot rating, but they don't just ALL get consumed/'sheared'. I'm not saying VIIs are good, just that they don't behave as badly as you indicate.
Jeffry, look at the maximum temperature listed, not the spread. A straight 40 is listed up to 122F, 10W-40 is only listed for use up to 41F.
SG oil was the current rating at the time, but these listings allow back to a SE rating, which was 1970's technology. Given what we now know about multi grades of that era, maybe those German engineers knew what they were talking about.
I agree that those recommendations are not realistic with the current multi grades.
Ed
i can understand their lack of trust for the multi vis oils of the time. this tempature chart is probably no longer valid with todays multi vis oils which i assume hold their intended grade far better than yesterdecades oils.
In the link provided you'll see this Motorcycle engine killed the Delvac 1300S 15w40 in 3k miles shearing it down by 2 cSt's . You will also see that the Delvac uses almost 1k ppm more zinc than the thinner at both 40c and 100c Rotella 5w-40 which faired better in both wear and shear in the same engine , a Honda 750 Nighthawk with hydraulic lifters . These particular engines are pretty easy on oil too compared to some other engines out there .
If the vi improvers are better in the Delvac 1300S than in distant past oils I suppose the old stuff was pure junk
Bike analysis
Bikes are fun but click below for an alternative to your current weekend fix
High Risk out of Oklahoma
[ March 07, 2004, 07:31 AM: Message edited by: Motorbike ]
