Interesting Oil Observations!
Up here in the NorthWest
Engine: Ford 3.8 V-6
Miles: Currently 162,323 miles
Oil change interval 5,000 miles
Pennsoil Platnium 10-30w 5,000 miles = 2.5 quarts used
Valvoline Synpower 10-30w 5,000 miles = 3.0 quarts used
Mobil 1 0-30w 5,000 miles = ZERO quarts used
Comments?
Originally Posted By: Spyder7
The iron content sealed your leak.
-Spyder
-Spyder
I see you already caught the usual BITOG jokes.
Yeah. The invitation was too easy, I couldn't resist taking it.
Edit: on a more serious note, it may not be the brand (although that conclusion is a logical one), as the first 2 were 10W-30 while the Mobil was 0W30. Its also plausible that his engine is better suited to a 0W30 oil. Or both. Those are the only 2 variables we're being given, and both are different.
-Spyder
Comments?
How many OCI's did you do of each before switching to the next oil?
Maybe the M1 fixed a leak, because it was not primarily a burning issue?
One thing I can tell you for sure:
Cars that have been around the world 7 times normally don't fix themselves with an oil change. This is really rare!
+1, changing brands can have an affect. It's not uncommon for an engine to use some oil after changing brands, but then it settles down. It's not guaranteed b/c a lot of people change brands often and have zero consumption, but it's also not uncommon.
On a similar note, when I switched my vehicle over to M1 0w-30, it was the first time that I had to top up between oil changes. I'm currently on my second oil change of the M1 0w-30 but I haven't checked my oil level yet so I don't know where it's at
You are sooo right.
M1 AFE is not promoted as having any special benefits for a high mileage engine.
Maybe it does?
Comments?
The order of the changes when this way and only for 5K before switching to the next oil.
PP, Synpower, M-1,PP
Do you think votality has anything to do with it?
Originally Posted By: jorton
Before you changed oil with M1 did you service the pcv, pcv hose? If not, the oil could have done it for you.
All routine oil changes....no other cleaning was done! Only the Mobil 1 change went 5K without a top off.
Comments?
