So I have a friend of mine that I have done oil changes for him and his family for years now. He has a 2008 GMC Yukon Hybrid with a 6 liter motor that he bought used with about 120,000 miles on it. The first owner was the Canadian Govt. Uses about 3 quarts of oil each OCI no matter what oil is used. Runs great.
When he bought it the used car lot sent it over to the local "Fast Eddies Oil Change" for a fresh OCI. A few days later he called me up in a panic stating that the oil pressure warning light was on and the gauge dropped to near zero PSI. I went over to his house, couldn't find anything wrong but did a complete oil change replacing the made in China filter with a Fram Ultra and 6 quarts of M1 EP 5w-30. Bingo, everything worked with no issues.
Since then I have done all his oil changes with no issues using oils such as M1 EP, Valvoline Maxlife Syn and Pennzoil Ultra with Fram Ultra filters with no issues.
Fast forward to last week. His current set up is PU 5w-30 with an FU filter, 53% left on the OLM. He calls me up with the same problem. Oil pressure dropping light going on. I go over, start up the truck when it's cold. Jumps to about 70 PSI and after 4 minutes or so it slowly loses pressure to about 10 PSI at idle and as usual, can't find any glaring issues. Drain the oil and replace with PP and an ACDelco filter. Bazinga! No problems, great oil pressure and no warning lights.
So what's the deal here? Why is this happening? What am I missing?
