Been doing some general research on this oil for my RX-8, and I think I found some things that might be of interest more generally. I want to first lay out some of what I've found, and then offer my interpretation for feedback.
The oil:
Idemitsu Racing Rotary Engine Oil (10W-30)
It’s a PAO-based 10w30 with some ester content. Supposedly optimized for rotary engines, but I wonder if it might be useful for other engines as well. More on that below.
Got some unpublished info on it from Idemitsu (HT Marlena):
- HTHS: 3.46 cP
- 600-800 ppm moly as MoDTC
- Sulfated ash: 0.88%
How often do you see an oil with that much moly and so little sulfated ash?
I looked for used oil analysis and VOAs for more details, and found only this:
(Clipped from this post: https://www.rx7club.com/3rd-generation-s...3/#post10754140)
Looks like a moderate amount of ZDDP, a fat slug of moly, and a very moderate amount of Ca. Little or no Mg, some B.
The oil has been updated at least once since then (latest update 2014), but the numbers are consistent with what I’ve heard and read from Idemitsu.
Am I right to imagine that all of the above seems to imply a different formulation strategy vs. most oils? To my amateur eye, it seems to be part-way between a typical PCMO and a low-detergent race oil. The primary emphasis seems to be on AW/FM, with limited amounts of detergent/dispersant keeping ash low and reducing competition with the AW/FM; the latter point means they could use moderate levels of ZDDP, further reducing ash, but still retaining a very high level of AW performance.
I guess they could be using ashless detergents/dispersants, but I'm assuming that's unlikely at this oil's $8/qt price point, which already seems cheap for a PAO/ester oil. If that's a bad assumption, someone please correct me.
If I'm right -- which is a big IF, as I am not remotely an expert in the relevant field -- I bet this could be a killer option for short OCIs in many kinds of engine. Most other oils that promise high AW performance and have a lot of FM also have a bunch more detergent/dispersant, which may be useless or counterproductive for short OCIs. I wonder if this oil might beat them for AW performance. It'll certainly beat them on ash formation.
Thoughts? Corrections? Comments?
The oil:
- HTHS: 3.46 cP
