- Messages
- 34,063
- Location
- Southern NJ
This is interesting.
"Dear Sirs!
I am the beginner on yours Board. Let me to tell some words about me.
I am from Kazakhstan. I am Product Engineer of company that distributes the Chevron lubricants. I hold frequently educational seminars with ours customers and clients. We always consider a circle of problems affected on it board.
I chose the basic problems of the your discussion:
· why in Europe the oil drains intervals are more than in USA? May be base oils and additive package in Europe are better?
· how to determine «exact» drain interval?
· how to select oil for the vehicle?
I shall begin from the first question and if my answer will be interesting for you I shall keep on later.
The answer why in USA drain intervals of oil are LESS than in Europe hides in the design features of engines from USA and Europe.
In the American engines the upper compression ring of piston is located almost on a piston head. It is considered (and it is the truth) that fuel composite that located between the wall of cylinder, the first piston ring and wall of the piston does not burn. The large masses of metal do not give temperature to be pushed up prior to the beginning fire. Therefore, unburned fuel will be rejected in an exhaust pipe. Someone will tell that this amount very little. But the sea consists from the drops! Thereat the American designers have located the first ring, as it is possible above. Now it gets into combustion zone. The oil that accumulates on this ring at piston move to the top dead center is burn too. I am sure that you know, that after combustion of oil forms an ash (not sulphate). It is solid rest. This rest, accruing on a piston ring, plays a part of abrasive that reduce a wear. Besides you know, that the detergency, dispersancy, total base number etc. are directly depend on amount of ash. Engines designers and oils manufacturers are come to an accommodation - ashy additives so much to not cause abrasive wear, but not so much for long life.
European engine manufacturers (and Japanese too) have pulled down the upper compression ring below, so that it did not fall in combustion zone. The oil on it does not burn, therefore and will not be to form of the abrasive rest. It is possible to raise ash content in oil together with increasing TBN, detergents, dispersants and so on. With increase of these performances is increase endurance of engine oil usage also. Therefore at usage of the AMERICAN oil in the AMERICAN engines the drain interval is less, than at usage of EUROPEAN oils in EUROPEAN engines. I am sure you can to view independently alternative versions of oils and engines. As to base oils and additives, they are practically identical in Europe and USA. There are only minor differences. Unfortunately bulk of post does not allow prolonging. If for somebody interesting prolongation I shall be on contact.
Yours faithfully,
Mikhail
