Interesting Difference in Ford Specified Oils
AL
At my previous job we had a 2021 Ford Police Utility Interceptor aka an Explorer with the aspirated 3.3 V6 and the oil cap had 5W-20 emblazoned on it. At my new job, we drive a 2021 an Explorer turbo 4 cylinder that has 5w30 emblazoned on the oil filler cap. Hmmmmm, guess 5W-20 can't take the heat that an "Eco Boost" dishes out.
🎣 what is the actual point of this post? You’re comparing a na engine to a boosted one
...and in more breaking news! Some cars require 93 octane while others (gasp) make due with.......87.😳
Being sarcastic about the BS of the thin oils being as good or better than the higher viscosity oils. Apparently not when you introduce the added heat and stress that turbocharging puts on engines.
Someone needs to put 10w40 in an engine which specs 5w20 and see if it blows up..... or at least give us some oil pressures of each oil cold and hot.
I bet no one will.....
I run a synthetic 5w40 in place of conventional 5w20. Hasn't blown up. Could care less about oil pressures. I have a couple jugs of 0w40 to run before I can switch to 10w40 or 15w40. I bet my engines won't blow up.
Is this sarcasm? I’m running 5w40 in an engine calling for 5w20 previous fill was 15w40, why would it blow up if not sarcasm
  • Like
Reactions: wlk
I ran my f150 3V 5.4liter V8 (spec'd for 5w20) on 0w40 for over 5 years. Plenty of those engines were run on multi fleet oils for all of their lives that are Xw40 weights. I run the same Castrol EDGE 0w40 in my current F150 3.5 eco and have since its first oil change at 500 miles. Temps below -30C right to 40C in the summer towing through the mountains.
