I am looking to replace the inake manifold gasket on a Vibe. I got an updated gasket from the Toyota dealer (not sure why GM doesn't carry the updated gasket).
Here is the TSB for my problem, and it discusses how to do the procedure. http://www.toyotapart.com/M.I.L._ON_DTC_P0171,_AND_OR_PO133_ENGINE_RUNNING_LEAN_IN_SUBFREEZING_AMBIENT_TEMPERATURES_T-EG045-07.pdf
My question: what should I use to clean the surface where the manifold gasket sits?
Also, do I just put the new gasket in place, or do I need to put grease on it in order to keep it in place?
Any other suggestions on the process?
